Re: Super A governor problems
Posted by Janicholson on April 05, 2012 at 21:57:52 from (96.24.99.126):
In Reply to: Re: Super A governor problems posted by old on April 05, 2012 at 14:53:11:
I agree. If adding a whiff of propane into the air intake at the carb makes it smooth out, it was lean. Cheap and easy diagnosis. Use a torch with the mixing head removed to get pure propane. Tight carb bushings in the throttle plate, and linkage with loose rod joints will also make surging. Jim
