Re: International/farmall 544 TA problem~ Please help!
Posted by mkirsch on April 06, 2012 at 05:42:11 from (64.80.110.74):
In Reply to: International/farmall 544 TA problem~ Please help! posted by Tom122047 on April 05, 2012 at 19:43:05:
You need to figure out if you're in Direct or TA before you decide anything.
If the tractor is in TA it will freewheel (coast) out of control going down hills. This is extremely dangerous because the brakes on these tractors aren't that great. Also the extreme speeds experienced by the components in the transmission when this happens can cause them to fly apart. The problem needs to be fixed.
If the tractor is in Direct, it will be okay to drive it as-is, basically forever.
The test is to take the tractor out and drive down a hill with it. Make sure you have good enough brakes to stop the tractor first. If it coasts you're in TA and need to fix the problem.
