Posted by TimWafer on April 06, 2012 at 12:34:20 from (69.193.106.146):
In Reply to: 656 front axle posted by TimWafer on April 03, 2012 at 16:23:43:
Still working on adjusting this axle. Pretty much have tried all the suggestions including bumping into a wall & driving it around a while with the clamps & pins removed. Also removed the spindle and replaced it with a 5 foot heavy walled pipe and pulled the end towards the rear axle with a come-along until the pipe was bending. All the while heating and hammering on the tubes. The tubes haven’t budged even a hair.
So finally have removed the entire front axle and stripped it down to just the outer axle tube and the two adjustable insert tubes. Tonight will rig up a better way to heat it and can at least get a good swing at all sides with a sledge now. Then may weld up some brackets so I can use a 20-ton jack to try and push them apart. I blew apart a 12 ton jack already but didn’t have it really squarely aligned hence the need for the brackets.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
