Re: International/farmall 544 TA problem~ Please help!
Posted by Janicholson on April 06, 2012 at 22:00:16 from (96.24.99.126):
In Reply to: Re: International/farmall 544 TA problem~ Please help! posted by Tom122047 on April 06, 2012 at 21:11:00:
I believe there is one other pesky thing. If it seems to shift on its own as you lift the implement(when in direct drive (Lever forward) and pulling tillage implements, then it will very likely need the direct clutch rebuilt. Probably both at the same time. There may be an adjustment on the clutch, but as I said I have not seen the tractor. Getteing a repair manual is a good idea. Jim
