Re: Farmall H valve job
Posted by rustyfarmall on April 07, 2012 at 06:28:35 from (216.248.71.224):
In Reply to: Farmall H valve job posted by jbp on April 06, 2012 at 18:10:22:
The engines in the H and M are really no different than an engine in a Cub, A, or B. They are simply bigger, and heavier, and the H and M use dry sleeves instead of the wet sleeves found in the A and B. If you can work on an A, you can work on an H.
