Farmall 400 Exhaust Manifold Torque Specs
Posted by mnryegrower on April 07, 2012 at 07:27:43 from (209.212.37.231):
I have been searching the net and this site for the proper torque specs for the exhaust manifold bolts on a gas farmall 400. So far I have seen numbers from 25 all the way to 55. would like to know if anyone has the correct specs for these. Also, I do not do this often, any advice on proper technique? I am under the impression you tighten from the inside bolts and work your way out starting with a low torque number. Then repeat working up to a higher torque number until the proper torque is reached. how many steps would be wise to use? should they be checked and retorqued after warmed up?
Thanks for any advice.
