mkirsch said: (quoted from post at 13:06:48 04/06/12) It would be interesting to perform the same comparison of steel vs. rubber as was done in the 1930's to see if the tire manufacturers have been stringing us along for 80 years...
In 1934 the Allis Chalmers WC was the first tractor to be tested with pneumatic tires by Nebaraska Test (test #223). Actually they did a comparison on the same tractor with both steel and pneumatic tires.
It is all interesting reading, but any way you want to look at it the rubber tires were more fuel efficient on the same drawbar loads by quite a bit - not to mention operator comfort. In my opinion, the fuel savings would even be greater on a more modern tractor as you would have the luxury of more gears to choose from on a modern tractor in order to pull the rubber tired loads much faster. The test in 1934 used the same tranny gear for both tests as that was the rated working gear by the manufacturer (Of course back in the 1930's tractors often only had 2 or 3 gears anyway).
I have never operated a steel wheeled tractor, but I do use a couple of older steel wheeled hay rakes. My fields are realatively smooth, but some of the sounds that rake will make when it hits a bump literally make me cringe - and very thankful my poor body is not being subjected to that same shock load.
This post was edited by rankrank1 at 10:54:20 04/07/12 4 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
