T/A and clutch(es) were just replaced. The tractor is in direct, but the shift lever jams in gear once it warms up.
The problem is that there is no space between the T/A pressure plate cover and the friction plate in the pressure plate assembly, i.e. there in no room for the friction plate to lift. The T/A linkage is disconnected and the throwout bearing is not touching the levers on the pressure plate.
Service manager at our local IH dealer was mystified, but had helpful suggestions for getting the clutch out without removing the T/A..
I'm going to try 1/8" shims between the pressure plate and the flywheel.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
