Re: farmall c/sc/200/230 alternator
Posted by mkirsch on April 07, 2012 at 14:23:58 from (67.253.161.186):
In Reply to: farmall c/sc/200/230 alternator posted by nl00sb on April 07, 2012 at 12:48:22:
These are some of the easiest to convert because the generator is down on the side of the engine. Usually you can just bolt the alternator on directly in place of the generator using 3/8" all-thread and some strategically-placed nuts and lock washers.
