the rims with the square tag are an OZZIE wheel , the square tage is to stop the rim from spinning, it is possible to use a rim without the tag on a center that has the notch in it , all the AW7D and 554 have the notch front wheels , it is also used on all the pressed steel rim rear wheels its the only way of stopping slippage as they are a driven wheel.
if you have a AU tractor that has a front wheel without the notched hub -it has simply been replaced at some time (as when they are left to rattle around loose it will destroy the hub enough that you will not be able to keep rims on tight) you will notice that most IH wheels parts that are made in AU have AP on the casting numbers somewhere...pat
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
