Re: Farmall 300 Timing Marks
Posted by ken church on April 08, 2012 at 03:07:35 from (75.219.60.83):
In Reply to: Farmall 300 Timing Marks posted by Kevin (Allendale) on April 08, 2012 at 02:16:17:
The way I do it is remove number 1 spark plug and hold your thumb over the hole (be sure switch is off or remove coil wire) you can feel when the compression pushes your thumb. then line your rotor up with number 1 in the cap. this should be close enough to start then adjust your dist. until it runs the smoothest and retard just a little. Hope this works for you.
