Re: 706 dies under load question
Posted by MN Scott on April 08, 2012 at 07:02:55 from (184.158.72.198):
In Reply to: 706 dies under load question posted by RMF1066 on April 07, 2012 at 20:28:07:
Classic too high heat range spark plug symptoms. Install a set of champion D15Y"s or the equivalent brand of your choice and your problem will be solved. Also The Tractor Vet is 100% correct about running 93+ octane gas if you work these old gassers. BTDT!
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
