There are four bolts between the hub and the housing on the outside that holds the bearing and seal in, this needs to be unbolted since this piece will come out with the axle. Like was said earlier the cap on the inside needs removed, and the nut and bearing taken off the inside. On this I just let the bearing slide off of the shaft as I pull it out. Make sure you support the bull gear as this will drop out of there when you pull the axle shaft out of there. good luck
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
