Re: Super M wide frt end
Posted by david G on April 08, 2012 at 14:09:26 from (205.215.206.18):
In Reply to: Re: Super M wide frt end posted by jtbartlett on April 08, 2012 at 13:29:31:
There should be some toe in, about 1/8 to 1/4 depending on how good of shape the tie rod ends are in.
I jack up the wheels and scribe a line in the dust on the tire with a screwdriver while I rotate the tire. You can then get a precision measurement.
Make sure the bearings are good and have a little preload while the wheels are jacked up.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
