Re: C-263,, Sleeve removal
Posted by cole in mo. on April 08, 2012 at 16:35:30 from (65.255.149.240):
In Reply to: C-263,, Sleeve removal posted by John A. on April 08, 2012 at 15:49:58:
Not sure of the bore size, but more that likely when you pull the head you"ll notice the sleeves are junk. Most times I use a sleeve puller, its got several different sizes of plates to pull most sleeves. Sometimes I run a weld bead from the bottom up, and a little later it comes up by hand. They go in hard, need to clean the block bore good, place sleeves in dry ice, make sure they seat right the first time.
