Re: farmall 230
Posted by El Toro on April 08, 2012 at 16:45:13 from (108.3.225.57):
In Reply to: farmall 230 posted by tom grim on April 08, 2012 at 16:29:35:
Your ignition switch may be the problem. Locate the wire that feeds battery voltage to your coil
on your switch. Pull that wire off the switch when the engine is at an idle and see if the engine stops. Alternators can cause voltage back feeding causing the engine to keep running. Your switch may not have a good ground. Hal
