9 K ouch . Ok on your miss here are COULD BEE"s IF the injector is cracking at the correct pressure and your PRECUPS are installed correctly and all is well there you SHOULD BE GOOD . notice i said SHOULD be . Now with out hearing the engine myself we are playen the it could be game here DID you have the injection pump rebuilt by someone that is old and knows these pumps inside and out ?? as IF the cam bushing in the pump are the least bit worn the can will now run true and this will plum drive you goofy . The other thing that will cause a miss in these engines is a crack in the block and most times that crack in in the #2 or #3 cylinder between the two holes , not what ya want to hear. And Oh BTW you could have bought kits , OEM kits from Clyde Burkshire in Royal Center In.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
