Re: Farmall m vs. farmall h
Posted by dej(Jed) on April 09, 2012 at 05:40:42 from (141.189.113.1):
In Reply to: Farmall m vs. farmall h posted by Ole Reds on April 08, 2012 at 22:03:30:
I have had loaders on both H's and M's, both do an okay job. One H with a JD 45 loader did an exceptional job. It had trip bucket , but the whole setup was very user friendly for some reason. Since the bucket capacity is roughly the same on these old loaders, I would rather wrestle with an H than an M. You really don't gain anything with the M on the loader. Also the Arm strong steering system can be a real bear. My $.02 worth.
