Re: Farmall H valve job
Posted by CoopertownBob on April 09, 2012 at 15:02:23 from (74.51.5.123):
In Reply to: Farmall H valve job posted by Andrew Z on April 06, 2012 at 18:10:22:
As long as you oiled them well, nothing really. If not, run a few squirts of oil down each one when you adjust the valves before first firing, if too late for that, don't worry about it. Don't forget to re-torque the head after the first run to operating temp. 70 pounds. And there is no real need to pull the steering shaft either, it just makes it a little easier too pick up the head and to replace it, but if you pull the front-most two studs, you can pull the head without removing the shaft.
This post was edited by CoopertownBob at 15:04:44 04/09/12.
