Re: International 5100 grain drill
Posted by randy hall on April 09, 2012 at 15:31:36 from (216.255.28.121):
In Reply to: International 5100 grain drill posted by don656 on April 09, 2012 at 11:08:46:
to sow lower rates. to choke the fluted feed down to 180000 per acre you would be sowing bean meal. cut the shaft speed in half and you don't grind the beans up.
