Re: Farmall A Genrator Pulley Not Turning
Posted by CharlieNJ on April 09, 2012 at 15:35:30 from (76.117.68.151):
In Reply to: Farmall A Genrator Pulley Not Turning posted by Perk on April 09, 2012 at 03:38:40:
Perk, I had the same situation on my AV last fall, so we took the pulley and hub off. It looked to be an aftermarket assembly, and the spot welds let go. So my son put some spot migs on it and it works fine. He welded the two pulleys together on their edges.
Also called CIH parts department, they said to bring it in to match it up, they had two different units available and they were in the neighborhood of $275.00. Hope you have the best of luck with yours.
Charlie
