Re: What is the difference between...
Posted by CharlieNJ on April 09, 2012 at 15:48:48 from (76.117.68.151):
In Reply to: What is the difference between... posted by Joe in CA on April 09, 2012 at 14:33:21:
Joe, all the A's had 113 ci engines, some Super A's had 123 ci. Some Super A's had water pump, no A's had pumps. Grille on the Super is taller I believe. Early A hoods had Zeus type fasteners. Torque tubes are different due to hydraulics. Super engines had flange to mount the hydraulic pump, A's did not. Some A's came with out starters from the factory. Late model Supers had a different dash. Due to a different starter switch arrangement, on the A you push the starter rod, on the Super you pull the rod to start. Many other internal parts were upgraded in production. If your swapping parts, check the CIH parts book online for details.
Best Regards,
Charlie
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
