Re: 47 cub
Posted by Denny ('60 Lo-Boy) on April 09, 2012 at 17:25:18 from (76.2.224.19):
In Reply to: 47 cub posted by whig on April 09, 2012 at 17:04:05:
Do both a dry and wet compression check. Do the dry first and note the compression readings. Then put a little oil in the cylinders and do it again. If the reading rises the rings are worn, if not then the valves are leaking.
