Posted by pete 23 on April 09, 2012 at 17:39:58 from (74.32.231.176):
In Reply to: Push rods on a 1947 H posted by John Fulton on April 09, 2012 at 14:54:48:
No problem, but you should reset valves after running long enough to get warm as those push rods will work their way into place. You can usually prove this out pretty easy by , running an engine for a while, check the clearance on a given valve with engine turned to proper position for that valve, then just grab a hold of that rocker arm and move it taking up the clearance. Now, recheck your clearance. If every thing is not brand spanking new the clearance will most likely be different. That is why you run them, check clearance before even touching the rocker arm as it has found it's running home. OH, .017 on an H.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
