Re: super a overhaul
Posted by CNKS on April 09, 2012 at 17:56:29 from (216.144.104.128):
In Reply to: super a overhaul posted by thetractorfreak on April 09, 2012 at 15:45:05:
Gene is correct, but you only have two choices, both with larger sleeves than the standard 3 inch those are either 3.125 or 3.25. The 3.25's will only fit if the block part number is 354898, the others take the 3.125 sleeves. I don't fully trust this site as to serial numbers, and do my own research. Be sure you get the head gasket with the large holes. The SA has a thermosiphon cooling system, the Super A1 has a water pump and smaller holes in the head gasket. If your tractor has had a water pump added, either gasket is ok.
