Re: Can you run engine without any oil in trans?
Posted by JRSutton on April 09, 2012 at 18:27:52 from (75.130.109.233):
In Reply to: Can you run engine without any oil in trans? posted by 400D Guy on April 09, 2012 at 16:53:27:
Remember that even when it's in neutral, the main drive shaft in the transmission is spinning at the same speed as your engine.
So I'd run it just as long as you'd run your engine with no oil.
I'm sure in reality there will be some residual oil left in there on everything, as long as it hasn't been weeks since you drained it. And it'd probably would be fine for a quick trip... But as a friend of mine likes to say "they ain't making any new ones" - so why push it.
If you decide to do it, make sure - as somebody else pointed out - to keep the clutch depresed while idling. Then just pop it out long enough to make that short trip, then kill the engine.
And a final note - you might be surprise how easy it is to push the tractor, even a 400. Just use one of the rear tires for leverage. If you push up on the wheel to turn it, you can single handedly move the tractor pretty easily across flat ground. (have somebody sit on it to stop/steer it of course).
A lot of people don't realize how easy it is to do.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
