Re: f-12 help
Posted by Old-F20 on April 09, 2012 at 20:34:25 from (71.7.101.5):
In Reply to: f-12 help posted by missouri jeff on April 09, 2012 at 20:10:46:
ive got an F-20 that did the exact same thing. what it turned out to be was grease from the throwout bearing had flung out while running and got between the cutch disc, the flywheel, and the pressure plate. it created enough of a suction that you had to step on the brakes to get it to break loose
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
