Posted by El Toro on April 10, 2012 at 04:34:56 from (108.3.225.57):
In Reply to: 47 cub posted by whig on April 09, 2012 at 17:04:05:
You probably need to rebuild the engine. Have the cylinders measured for wear. They may need to be bored oversize. Have the crankshaft measured too. Buy your bearings from them. Have the shop to do a valve job. I would install new valve springs. Hal
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
