Re: What is the difference between...
Posted by JRSutton on April 10, 2012 at 04:51:46 from (75.130.109.233):
In Reply to: Re: What is the difference between... posted by Joe in CA on April 09, 2012 at 21:24:27:
Just to complicate things - some A's were modified by their owners to have hydraulics.
The super A's have a distinctive "touch control" box mounted under the gas tank, in front of the battery box.
If you look at pictures of A's and super A's it's very obvious. A's are empty in that area - the super A's have that big box with the rockshafts coming out of each side. Can't miss it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
