If you can read the stamped-in numbers on the serial plate, if the number is 250001 or higher, it is a Super A.
Of course the seat support with the serial number could have been changed out for one off of an earlier A due to rust or other damage.
Having parts interchangeability does not make things easy sometimes. You could easily end up with a "Frankentractor" made from parts of several other dead tractors and brought back to life.
The "hydraulics" that make a Super A, a Super A, come in the form of the Touch Control block under the gas tank.
There have been all kinds of cobbled-up hydraulic systems added to regular As over the years, power steering pumps driven off the fan belt. They do not turn an A into a Super A.
You could also get a self-contained "Char-Lynn" hydraulic unit that mounts on the PTO. They do not turn an A into a Super A.
Only the Touch Control system makes an A into a Super A.
To complicate matters, there are a few As out there that have been heavily modified with Super A parts to add the Touch Control. In order to make this work you needed to swap out the entire engine block, and the "torque tube" section of the rear of the tractor.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
