The points ARE adjustable! Should be either an eccentric screw or a pair of slots (one in the fixed point frame, the other on the plate the points are fastened to) to facilitate setting the points.
To set, first turn the crank until the points rubbing block is at a high spot on the cam. Now loosen the points mounting screw a bit, then use a flat blade screwdriver in the eccentric (or slots) to set the gap.
Be sure to check the gap after retightening the clamp screw to make sure it hasn't changed.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
