6 volt Generator
Posted by J.D.HEICHEL on April 11, 2012 at 02:27:27 from (67.235.0.138):
When checking the voltage output on the generator and voltage regulator what post do you place the positive and negative leads from the multimeter on? What do you set the multimeter switch to? How much is too much for the generator to be charging at? I had a problem with it overheating. The guy that rebuilt it said it had to much paint on it where it bolted on the brackets and it wasn't grounded. I took it back for him to check it on his test stand it put out 18volts at first then we cleaned off the paint and it put out 13.5 volts. I am guessing the voltage reg. takes care of the excess voltage for a 6 volt system??
