Re: Super A 193 plow question
Posted by mkirsch on April 11, 2012 at 06:10:02 from (64.80.110.74):
In Reply to: Super A 193 plow question posted by WellWorn on April 09, 2012 at 07:58:34:
WellWorn,
There are no "right" holes for the plow. Yours doesn't have to be mounted the same as rootsy's to be "correct."
You mount it to whatever holes make it take a full-width cut. That depends on how you have your wheels set.
If you have the tread width set very narrow, you install the plow closer to the center of the drawbar.
If you have the wheels set wider, you install the plow closer to the right side.
