One More Christmas Tree Valve Question
Posted by WI Dave on April 11, 2012 at 06:17:41 from (66.190.51.243):
I bought a tree valve for my H. It was not used by the PO, and my tractor is in 100 pieces in my garage, so I can't test it to see if it works properly. When the control lever is pushed forward, the spring will return it to the center position like it should. Should the spring also return it to center when the control lever is pulled back? (mine doesn't, there's no resistance/return to "hold" position when the lever is pulled back)Hopefully I explained that well enough...
