All that other advice you need to follow, but be sure the transmission housing is not flooded. Remove the bottom drain plug and see if any water comes out. If yes allow all the water to drain out before replacing the plug. You then need to consider cleaning and replacing the transmission housing of the wet oil crud ant there are plenty of post on here on how to do that. The reason I am saying this is that the seals are not designed to withstand constant pressure but to minimize oil loss due to splatter. Normal oil level is below the seals. Since these old tractors gain water in the transmission when stored out in the rain (and then not run to dry it off), you might want to look into this issue before you replace the seals. You can make a quick check of the oil level using the level plug on the rear of the housing under the belt drive.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
