Re: farmall super A... water pump or not???
Posted by RTR on April 12, 2012 at 06:33:09 from (216.226.179.180):
In Reply to: farmall super A... water pump or not??? posted by J.D.HEICHEL on April 12, 2012 at 06:12:00:
Engine Serial Number will tell you alot. Engines in these old tractors have been swapped around for years. THe block and head part numbers will also tell you something. The part numbers will end in "R1" or "R2". The engine serial number will be used like the tractor serial number and they should be close. It can be found on the side of the block just behind the governor on the distributor side. It is found on the flat surface painted silver in my photo
Quoting Removed, click Modern View to see third party image
