Re: seating a tire bead 20.8x38 tire
Posted by The tractor vet on April 13, 2012 at 06:21:55 from (75.19.127.43):
In Reply to: seating a tire bead 20.8x38 tire posted by Yellott Canby on April 12, 2012 at 19:24:25:
First off get yourself some Murphy's oil soap the paste stuff and apply it to the beads and also the rim . Then air up to 35 PSI and let her sit now if you are mounting tubeless the like the other guys have said as tubeless can be a real pain if you do not have one of them air blasters that shoots a huge blast of air to puff the beads out . JUST NEVER GO much above the 35 PSI . Making sure that your rim is clean and smooth is a big plus .
