Re: 5088 transmission sentury
Posted by I luv farmalls on April 13, 2012 at 11:09:31 from (207.199.209.26):
In Reply to: 5088 transmission sentury posted by 5088 ih on April 13, 2012 at 07:07:10:
There is a electric bypass kit through Case IH that the mechanics can install to take care of that problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
