Posted by rustyfarmall on April 13, 2012 at 12:02:04 from (216.248.71.224):
In Reply to: 1955 IH 300 carburator posted by Country Doc on April 13, 2012 at 10:31:35:
If you lost the high speed idle adjusting mechanism, the tractor would most likely NOT run, and gasoline would be leaking profusely from the hole. Likewise if you lost the 1/8" pipe drain plug, gasoline would be escaping at a very high rate of speed. However, if you lost the welsh plug from the hole in the very bottom center of the carburetor, the tractor will still run, and gasoline will NOT be leaking out, other than MAYBE a drop or two sporadically. There is a felt filtering material that goes in that hole, and then the welsh plug is "driven" in to keep the filtering material in place. Any Case IH dealer should have that plug on hand. Any auto parts store will have a plug that will fit, but the plug from the auto parts store will need a small hole drilled directly in the center.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
