It sounds like may well be pressure switch under the floor board. They were known for problems of leaking internally and causing switch to close with equalizing pressure on both sides of the contacts. (Yes, the side you are operating in runs on an open circuit switch). In fact, you can unhook the affected side to see if the switch is the problem. It will only operate in that side then. I would not recommend using the bypass harness. No protection for lockup of both clutch packs at same time which will really tear things apart. The sentry is doing it's job, telling you something is wrong.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
