The 06-66 tractors are FULL FUEL when you turn the key on and it is the Same if you back the screw out five turns on the rest . The jet determines the fuel flow. , yes you can lean wean what ever ya want to call it on the rest . BUT if your working them open the fuel up . Running them FAT is better then lean . I have already fattened the 706 up when we did the overbore from 263 to 291 along with doing a recurve on the dist as a 263 runs more timing advance then a 291 . A 263 runs 23 Degrees BTDC and a 291 runs 18 .
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
