Re: alternator puzzle
Posted by Janicholson on April 13, 2012 at 20:00:02 from (96.24.99.126):
In Reply to: alternator puzzle posted by notjustair on April 13, 2012 at 19:05:43:
The L terminal is the vertical part of the T shaped connector socket. The S terminal is the cross bar on the T. The lamp used as a "idiot" light in the L circuit. This lamp is connected with one lamp lead connected to the Alt L spade connector, the other lamp lead is connected to the coil (where the ignition power from the switch is connected. (if it has a ballast resistor, it is connected at the ignition switch side of that device.)
If the use of a diode is chosen the diode is placed in the same place as the lamp, with the band end of the diode toward the alternator.
If a resistor is used, (10 ohm) It is placed in the same way as the light.
Jim
