Oh you can MOW grass , you can go for a long ride they can set all winter and restart in the spring NO PROBLEM , Just don't take a later 4 cylinder or 6 cylinder gasser and try and put her to work . the fuel requirements for that tractor are in the owners manual and are LISTED as MINIUM not maximum . We do not plow with the 706 anymore since we got the 1066 but the 706 does grind feed it does 90% of the hay mowing with a 1219 John Deere haybine , Sometimes it pulls silage wagons that weigh in at real close to 30000 lbs it sometimes runs the Krone 130 round baler or the john Deere 336 idiot cube maker it rakes maybe 60% of the hay four times a year over about 110 acres . First cutting can work the snot out of the 706 and has worked the snot out of the 806 diesel . The grinding of feed works her pretty good for about 15 min. where she is doing all she has to hold PTO speed , When the 806 is on the grinder she will put up a pretty good plume of black hooked to the New Holland 355 . We grind right at 35-3600 lbs of ear corn thru a 5/8th screen for the cows Then there is the sheep and hog feed when we get some hogs and that goes thru a 3/16ths screen . That is when either the 806 goes on the grinder or the 1066 and that grinding can bring either one to there knees . And oh we like the 706 on the corn picker it just seams like it is better suited then the 806 or the 1066 , it is a lot easier to pull the 706 out then say the 1066 when ya find that one wet spot that was not there last year.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
