Re: super h grill
Posted by D Slater on April 15, 2012 at 06:29:38 from (184.15.44.200):
In Reply to: super h grill posted by ajdeereman on April 14, 2012 at 20:04:24:
If you just need the regular SH grill with just 2 holes in front that correspond with threaded holes in the front bolster. Find a good H grill and fill the 2 small emblem mounting holes and then drill 2 small holes to mount the SH emblem.
It will look just like the most common SH grill and cheaper. Just stay away from the early H grills.
If you want the SH grill with 4 hole openings in front they can be found but spendy most times.
