Re: Starter button on M's
Posted by CNKS on April 15, 2012 at 13:50:13 from (216.144.104.128):
In Reply to: Re: Starter button on M's posted by Armand Tatro on April 15, 2012 at 08:51:43:
The early H's also had it on the lower steering post-- then it was moved up. Pete 23 may be right about it needing more pressure, I don't know why it wasn't moved along with the H's otherwise. Actually, with a cold engine I usually start my tractors from the ground because it is easier for me to manipulate the choke, thus I use the starter button instead of the rod. I grew up cranking tractors so it is ingrained in my brain to be sure it is in neutral first. I also let them warm up for a couple of minutes while I do something else.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
