Re: Super A 193 plow question
Posted by WellWorn on April 15, 2012 at 14:29:00 from (69.95.14.22):
In Reply to: Super A 193 plow question posted by sflem849 on April 09, 2012 at 07:58:34:
Thanks for the correction, mkirsch. I figured that out after a couple passes, watching how much cut it was taking with the rear in the furrow, but it's good to post for the next guy needing some info.
The wheel width is set "tight" (loads on my little trailer better that way), and it has had the 3pt conversion. I used the outboard hole (inner holes are used for lift links) on the right lift arm for the chain hook, and it bolted the front flange on the drawbar as it 'naturally' hung.
Judging from how it was working, I should move it over at least a couple holes, and will do so next time I need to put it on.
Again, the wealth of info here is nothing short of astounding.
Thanks again
