Re: Farmall 460 stuck in and out of gear
Posted by mkirsch on April 17, 2012 at 05:42:22 from (64.80.110.75):
In Reply to: Farmall 460 stuck in and out of gear posted by Dock09 on April 16, 2012 at 19:24:31:
Even if the clutch is stuck you should be able to slip the tractor out of gear while it's running... You can't even do that?
If you can slip the tractor out of gear, it's a simple rusty clutch. Block the clutch pedal down and drive it around a while. It may break loose.
Worst case you will have to split the tractor and replace the clutch.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
