Re: cultivator on b farmall
Posted by Janicholson on April 17, 2012 at 16:07:42 from (96.24.99.126):
In Reply to: cultivator on b farmall posted by jerry standerfer on April 17, 2012 at 10:26:21:
Look at the existing lift lever. The action of that lever when lifting needs to be duplicated with a cylinder. (front linkage steering cylinders from medium duty trucks (junk yard) are powerful enough.
Power the pump (from a powersteering system again from a medium duty truck) with a belt from the engine. Use an open center valve, and a 2 gallon reservoir. Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
