Re: Super H has water coming out of exhaust?? Help!!
Posted by pete 23 on April 17, 2012 at 19:28:45 from (74.32.231.176):
In Reply to: Re: Super H has water coming out of exhaust?? Help!! posted by Farmall Bob09 on April 17, 2012 at 19:21:14:
You don't really need a gauge, you can just snap an air hose onto the fitting on plug. I should have said, you take an old spark plug and smash the guts out of it to braze a fitting on it. Far as the gauge I use, I hook my air hose onto my gauge assembly and then there is another quick coupler on the other side of the gauge and I snap that onto the modified spark plug. This is not a compression test, it is a pressure leak down test. My gauge set up has two gauges with an orfice between them and I can tell the percentage of leakage from the cyl. They all leak some past the rings but should not leak past valves and definetly not leak into cooling system. You look into the radiator for leakage. It gets a little more complicated than that but this is a quick rundown .
