Might be a cracked block. I bought a W-4 (basically the same engine as an H) that was seized and couldn't get it to move so I took the head off and the cylinders were not rusted up. Penetrating fluid & some persuasion with a wood block got it loosened up. So I lapped the valves, put a new head gasket on and fired it up. Water and lots of it coming out of the exhaust plus it was missing on one cylinder. Took it apart again and pulled the piston out of the offending cylinder and there was a crack through the sleeve & cylinder wall that you could not see when the piston was in the cylinder. Farmall H's & W-4's have dry sleeves. I have seen a few IH blocks that cracked behind the sleeve. It can be an expensive repair job.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
